Salta al contenuto principale
How do I force start from CD?
My MacBook Pro won't boot up to the OS. I get the opening chime which then goes to the apple on screen, but then it goes all grey and gives me the message "You need to restart your computer. Hold down the power button until it turns off, then press the Power button again." This is as far as I can go. I have tried booting from a CD to no avail. What can I do?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
3 Risposte
Soluzione Prescelta
to force starting from the optical drive you have to press and hold the c key after the chime
Punteggio 3
that is is not working, nor is option, nor is option, shift, command, delete.
have cleaned the drive lense. and the disc is good.
sounds like a new optical drive needed?
Punteggio 0
1 Commento:
You need to ask your own question on this one as you seem to have other issues.
da
Perhaps the OS disk is too old for the Powerbook?
Punteggio 0
1 Commento:
This is an old post.
da
Aggiungi la tua risposta
Charles McCain sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,995
