Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
iPhone 4s LED flash problem
Hello everyone. I hope this is the right place to ask. Because I don't really know it is a software problem or a hardware problem.
I have a problem with my iPhone 4s LED flash. When I take a picture with the flash turned on, the picture become blueish or something like that. I think the problem occurred after I updated the iOS from 6.x to 7.
Can anyone identify the problem and solution to fix the problem?
Thank you.
Sample :
Sorry for my bad English. I hope everyone understand my question. :D
Questa è una buona domanda?
Punteggio 1
1 Commento
cant understand if the picture you took is a test shot to test the camera or to show us your phone. cause that's not a 4S. please specify.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
This type of issue is often just interference with the flash, either from a case, a screen protector, or some other cause (such as a finger too close to the flash). I don't know of any specific issues with flash between iOS6 --> iOS7. Have you already tried taking a picture without your case on to see if you have the same effect? Or perhaps a bit of plastic from a screen protector is too close to the flash? Sorry if this isn't your particular problem, but those seem to be the most common causes for this.
Punteggio 1
Aggiungi la tua risposta
Warnerin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,175
