Salta al contenuto principale
Modello A1286. Lanciato nel febbraio 2011 / processori quad-core Intel Core i7 da 2,0, 2,2 o 2,3 GHz
586 Domande Visualizza tutte
My MacBook has recently popped open now beeps-what do I do?
While working, my macbook made a popping noise, like a gunshot. Now it only beeps like a truck backing up when I start it up. The rest of functionality is completely frozen. What do I do if it is just past warranty?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Jessi Reel, the popping noise needs to be investigated properly. You will have to disassemble your MacBook, use these guides MacBook Pro 15" Unibody Early 2011 and take a good luck at the components. Check for any charred, missing or burned components. Also check your battery and make sure it is in good condition. Once you have done that, let us know what you found.
Punteggio 1
Popping noise sounds like the battery exploded. Open the bottom cover and remove it to see if it bulges. The macbook should still boot without the battery, so you can test it.
Punteggio 0
Aggiungi la tua risposta
Jessi Reel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 83
