Salta al contenuto principale
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433 Domande Visualizza tutte
Thermal Interface -Video Controller ASD Error
After recently replacing my GPU card and chip, I ran Apple Service Diagnostic 3S123 and discovered I have an error that states: Thermal Interface -Video Controller:G92gt (test #4) -TIM Test 75 percent Gardband-Check that CPU heatsink is properly attached, using product spec theta dh + 75 percent guard band.
Any suggestions on how to fix that? I can't find anything online about it. I don't even know where to look on my machine for that item.
Questa è una buona domanda?
Punteggio 1
1 Commento
I was careful with the screws and believe I am using the correct ones. Could you take a photo of the screws I should be using if you have them handy? I want to verify I am using the correct ones.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
When you replaced the card and GPU did you use thermal paste? I'd also contact Brickfence and ask them the same question since they did the repair.
Punteggio 1
2 Commenti:
I am using thermal paste and just replied it to the CPU portion again after the error/fail notice. After I reapplied it I got the same error message. Now I am wondering if it is the quality of thermal paste I'm using. I just emailed Brickfence too see what he suggest. Thanks for the suggestion and your prompt responses! I really appreciate it.
da
I've seen these types of error when the wrong screws are used (or missing) from the heat sink. I'll be interested to see what brickfense suggests.
da
Lynnor, this is not an answer but I can not add images to comments. This is to support "mayer"'s answer.
Punteggio 1
Aggiungi la tua risposta
Lynnor sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 916
