Salta al contenuto principale
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
Ipad Mini LCD has massive decrease in resolution after new digitiser
After replacing a smashed digitizer the LCD has suffered a massive decrease in resolution. I thought it might be the new digitiser, but when I tested against the original, the resolution wax still rubbish.
I haven't been able to fix after cleaning both the digitiser and LCD connectors on the main board, and have no other thoughts. I followed the guide to the most part, and was shocked when I put it all back together.
I have photos but am unsure how to post them.
Thankyou for any help.
Questa è una buona domanda?
Punteggio 1
2 Commenti
Try uploading your pictures to a website like imgur. You don't need an account and it's easy to post links to other sites. We won't be able to give you a good answer until we can see what's going on.
da
Aggiungi un commento
3 Risposte
Risposta più utile
You'll have to rule out damage to the LCD itself with a new one. Buy one you can return in case that is not it.
If problem is same with new LCD, then post here and we can help troubleshoot
Punteggio 2
That definitely looks LCD related, did it look that bad before you replaced the digitizer? Whatever caused the LCD to break probably did a number on the screen itself and that's probably why it looks like that. I'd recommend what jessabethany said and try a new LCD, if that doesn't fix it than you might be looking at motherboard damage.
Punteggio 2
Yep, it turned out to be a faulty LCD. it confused many because a faulty LCD will normally just die. This one didnt.
Leasson learnt.
Thanks for the help
Punteggio 0
Aggiungi la tua risposta
Aron sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 14
Tutti i Tempi: 817
