Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2193 Domande Visualizza tutte
Misc Issues when replacing battery? Restarting on its own and Error 29
Put in a different battery and then:
1) Phone will restart on its own intermittently
2) Show a different battery percentage every restart
--- WILL NOT INCREASE % WHEN LEFT CHARGING ---
3) Occasionally cause the LCD to shake in the corners
4) Will not restore via iTunes (ERROR 29)
I tried replacing the charging port, re-flowing the battery connector and cleaning the whole board.
When I place the original battery back in the device all these symptoms disappear and the device will actually restore successfully. I have tried multiple OEM batteries. This isn't the first time I have ran into this issue.
I am almost positive there is no board damage.
Any help would be wonderful.
Questa è una buona domanda?
Punteggio 1
2 Commenti
Turns out the batteries were faulty. Brand new OEM ... APN's: 616-0580
I have never seen this issue before but sure enough when I popped in one of my used batteries the problem was solved.
da
I have the same problem, when I replace 4s screen it's happen.
so I replace a new batteries, but it's still 29.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
If the original battery is working and no issues then it's a problem with the batteries your buying try a different battery from a different source
Punteggio 1
Aggiungi la tua risposta
Matt sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,501
