Salta al contenuto principale
The HTC One X is the first HTC phone to be equipped with a quad-core processor, released in April 2012.
42 Domande Visualizza tutte
Can anyone help with backlight?
I have an HTC one x that has no backlight. I can only see screen if I hold up a bright light to it. It has had no damage to it that I know of and no parts change. Can anyone walk me thru this repair as I have never repaired one before?
Thank you in advance.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Generally whenever I see this there are 2 possible solutions, once of which is not cool:
1) The LCD requires replacement (cross your fingers this works).
2) The motherboard in the phone has a bad fuse or something. This requires replacing the board/phone.
Is the phone under warranty? If it is, then that is likely the easiest way to get it fixed/replaced.
Punteggio 1
If you have the time and technical ability, replacing your phone's screen and digitizer may be the solution for a broken backlight. Be forewarned though, this is not an easy repair to do!
Punteggio 1
Aggiungi la tua risposta
Sue Tipton sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 6
Tutti i Tempi: 355
