Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
iPhone 4 backlight shutdown delay. Is there a fix?
Hi,
I just managed to replace the display assembly on my iPhone 4. The display is working fine but I noticed that the backlight of my display will shut down slightly delayed after the homescreen is already turned off. I made a little video to give you an idea of the problem:
http://www.dailymotion.com/video/k6ZOfma...
Best
Patch
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Where did you get your LCD assembly? It is likely a function of the assembly itself and not your phone. If you have another screen assembly try putting it on and seeing if that solves your issue.
Punteggio 1
1 Commento:
I got it from iFixit europe :/ The old (and shattered) screen didn't have this problem...
da
I would say that there is not a fix because this is not a problem....but that's just my opinion :)
Punteggio 1
Aggiungi la tua risposta
Patch sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 169
