PSU voltage: 12 V stable - 5 V NOT stable
Hi ....
i hope that someone here can help me.
I habe a problem with my G4 that won't turn on.
I tried everything i found on the web including change of 3.6 LiIon Battery and all the reset stuff.
I ended up with disassembling the G4 and took a look at my PSU.
I measured some of the voltages ...
AC / DC Board gives me more than 400 V of a stable DC voltage
DC / DC Board gives me a stable 12 V voltage between one black (GND) cable and 4 of the yellow cables of the mainboard-plug.
But between the black cable and the blue cable i get voltages between 0.8 and 3 and just sometimes up to 5 V .... it isn't stable at all .
I suppose there should be a stable 5 V voltage between the black and the blue cable??
I tried changing some of the capacitorc on the DC/DC board (2*10uf and 1*1uf) because i heard that they often are responsible for PSU problems but it didn't change anything.
Should i try to change the other capacitors too ?
Or could there be any other reason for the unstable voltage ?
Hope someone of you can help me
Thanks in advance
Oliver
Questa è una buona domanda?
