Salta al contenuto principale
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Domande Visualizza tutte
How to re-attach the "Display Data Cable"
So, a while ago my ipod stopped working, it was stuck in a loop of the startup screen. I didn't do anything for a while, but then more recently I decided to try and fix the home button so I could try and reset it. However, after taking it apart and putting it back together, I haven't been able to get it to turn back on. As far as my limited knowledge can tell, the problem is that I can't manage to re-connect the display data cable between the display and the body.
Extra: If I connect it to my Macbook, iTunes won't detect it unless I put it into recovery mode, which is why I think it is the screen. Also, it isn't the backlight because the screen isn't showing anything.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Put the display halfway closed and use a plastic tool to reach and press the cable in.
Punteggio 1
Aggiungi la tua risposta
XepherTim sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 130
