Salta al contenuto principale
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Domande Visualizza tutte
Charges up but doesn't charge
I have a problem with this iphone which im not sure what the problem is. The iPhone charges up to get to the home screen but then once it gets to the home screen it doesn't charge anymore. I'm not sure if it is the charging port or the motherboard but if someone knows what is wrong please let me know.
Thanks
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
1.Make sure the charger is in good condition.
2.You check the charging port whether it loose or not.
3.Clear the charging port.
4.Reconnect the charging port flex cable and battery cable.
5. If the problem still occurs, check the battery whether it work or not.
6. If the battery works, you can try to replace the charging port flex cable.
7. To replace the charge ic in the motherboard which should be considered as the last resort.
Punteggio 0
Aggiungi la tua risposta
Alex sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 83
