Salta al contenuto principale
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Domande Visualizza tutte
MacBook freezes with 8GB 2x KVR1066D3S7 4G Kingston RAM Modules
2GHz A1278 MacBook Unibody 13"
MB 5,1 with Boot ROM Version: MB51.007D.B03 running OS 10.6.8 freezes with Kingston KVR1066D3S7/4G (2 modules) 8GB.
Is there any setting for max mem or bootrom version, or anything else that can prevent the freezing problem?
Is this a brand issue?
Questa è una buona domanda?
Punteggio -1
3 Commenti
Can you please supply the last four digits of your serial number so we can correctly identify which model you have.
da
Dan, this is the only A1278 @ 2GHz
Apple MacBook "Core 2 Duo" 2.0 13" (Unibody) Specs
Identifiers: Late 2008 Aluminum - MB466LL/A - MacBook5,1 - A1278 - 2254
da
Thank you for answers!
Clearly the new RAM modules I got are incompatible with Macbooks. My MacBook indeed is Boot ROM Version MB51.007D.B03 and running on 10.6.8. I Tried all OS X Versions from 10.6 to 10.9.2 with the same modules (8GB installed), except the freezing problem (due to incompatibility) everything else looked OK. Actually it passed all hardware tests at a Apple service.
I should have checked the RAM modules before the purchase!
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
From the Kinston memory guide listing: KVR1066D3S7/4G & here is the spec sheet for them: KVR1066D3S7/4G 4GB 512M x 64-Bit PC3-8500 CL7 204-Pin SODIMM. This is not the correct memory for any MacBook system (by their listing).
Without a clear model listed to work off of I can't tell you what is the ideal memory is.
Punteggio 3
2 Commenti:
RAM Type: PC3-8500 DDR3 Min. RAM Speed: 1066 MHz
Standard RAM: 2 GB Maximum RAM: 8 GB*
Details: 2 GB of RAM is installed as two 1 GB modules, no slots free.
*Apple officially supports a maximum of 4 GB of RAM. Originally, this model was only unofficially capable of stably supporting 6 GB of RAM, but as confirmed by OWC, it is capable of supporting 8 GB of RAM if updated to Boot ROM Version MB51.007D.B03 and running MacOS X 10.6 "Snow Leopard" or higher.
da
Thanks Mayer for finishing the leg work.
da
Aggiungi la tua risposta
Burak sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 954
