Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Domanda Chiusa
GPS is intermittent after replacing battery
Replacing the battery went well.
BUT . . . my GPS now works intermittently. Any ideas what happened?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
6 Risposte
Risposta Più Utile
Check the interconnect cables they ate the long black cables that run up the center of the logic board they control the gps and download signals
Punteggio 2
Did you pry on the logic board side when replacing battery?
Make sure the connector below the battery is connected and that the interconnect cables are connected aswel
Punteggio 0
I'm having the same issue...did you get yours resolved?
Punteggio 0
Same problem here. Well, similar. My location just drifts and skips around now. Makes my GPS tracking app results hilarious but useless. I'm gonna break it open and check the cables, but any suggestions beyond the one above would be welcome in case that's not the issue.
Punteggio 0
Yup. I opened up the case earlier this evening. That connection seemed to be floating. I haven't had a chance to test it over a long distance yet, but the GPS location already appears to be more accurate. Pretty sure I must have dislodged that cable when replacing the battery. If I'm wrong, I'll report back. Pretty sure that was it, though.
Punteggio 0
Thank you, thank you, thank you. I too had replaced my battery and then lost GPS signal. Sure enough, the connector was loose. Tough little bugger to seat properly but I got it. Saved me a trip to the repair shop.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,516
