My right earpod is not working plz help fast
suddenly it is not worrking help plz
Questa è una buona domanda?
mohamd, you also should tried it on a different device. If it still does not work, it is possible that you have either a broken wire, a short circuit in the wiring, or a bad speaker. Jiggle the wires at the plug end with the earpod plugged in and see if you can hear sounds or a hiss. The plug is the only thing that you may be able to replace. Take a look at the teardown and see how the wiring connects. Just remember, even if you do take it apart and find a way to reattach the outer shell of the small speakers, it will never be the same. There are also no replacement parts available....Hope this helps, good luck.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 5,365
1 Commento
Might be time to buy a new set
da Crittie
