PS3 From usa 110V works at 220v?
Hi,
I just bought a PS3 320GB from USA, its writed 120V on the side of the ps3
I decide to move to my home country there we use 220V
Is it safe to plug it directly 220V ?
Questa è una buona domanda?
Hi,
LelRambo, the power supply in the PS3 Slim is a universal power supply to be able to operate 100-240V 50/60Hz. For validation, check on here as well as many questions about that in this Answers section;-) Hope this helps, good luck.
So all I need is a 220V adapter For the cable ?
All you need is the proper cable that will fit your electrical outlet.
Does this work with the fat older version as well.
I have a CECHP01
Thanks!
Baggie, yes it does
Does this work with The Superslim version?
Model:CECH 4201 C
thanks
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 13,410
1 Commento
yes it works i just tested my uk one it was 120v and i bought the correct cable tested in on 220-240v and works mine had its cooler fan disconnected and i got scared because i saw a console too hot notification but i resolved it very fast
da GAMELOGY
