Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
Domanda Chiusa
Wont sync or charge even after dock replacement
To begin i had a Iphone 4 Gsm model A1332 that was not charging (it would charge if the phone was shut off) or syncing (nothing recognized it tried 4 different computers and different cables on all of them ) and after research i decided to replace the dock connector. I followed the ifixit instructions step by step and noticed that the dock had water damage indicator was red but no other parts had the indicator set off. So after I replaced the part i have seen no change.
ps I double checked all the connections and they are snug and all other functions work.
Questa è una buona domanda?
Punteggio 0
1 Commento:
and forgot new battery too
da
Aggiungi un commento
1 Risposta
I would try a another dock that is known working and try it in your phone if that doesn't work the water damage has probobly destroyed a component on the motherboard but before all that I would clean the motherboard with 99% ISO alcohol you could also try a new battery just to rule that out
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 116
