Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2193 Domande Visualizza tutte
Home button malfunctioning - stuck on siri
The phone thinks the home button is always been pressed down. Siri continually opens and pushing the lock button usually causes the phone to screenshot. I have tried replacing the home button but it didn't solve the problem. I'm not sure if there's water damage or what but the water stickers are still white... I have also tried to restore the phone. Anyone know? Please help! Thanks
Edit: battery also does not charge, replacement battery does charge.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Replace the charging port cause the home button connects to the it and should sort out the charging
Punteggio 2
Next step would be to clean dock port with isopropyl alcohol. If still problem, replace charging port assembly. If still problem, then most likely logic board fault.
Punteggio 1
Aggiungi la tua risposta
Josh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,099
