Salta al contenuto principale
Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
52 Domande Visualizza tutte
Domanda Chiusa
Is the iPad 2 GPS antenna the same as the 3g antenna?
I accidentally ripped the GPS antenna in an iPad 2 CDMA clean off. Trying to find a replacement part, not a lot comes up for GPS antenna (as per the guide), but if I look for the 3G antenna, lots of results come up, and the antennae seem to look identical. Which one can I use?
The iPad no longer connects to a 3G network at all. In fact, once cellular is switched on it says "No Service" immediately, no searching or anything. Should I be concerned about this? It seems very quick to say no service...
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Ordered a "3G" antenna from a 3rd party. Worked fine as a replacement.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 144
