Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Domanda Chiusa
Can I swap the screen, back, and glass from sprint and att?
I have a white iphone 5 for sprint and also a black iphone 5 for art. Is there anyway to basically swap the back and front between the two so that the sprint phone is black and the art is white? Are there different parts inside that would make it not possible?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Yes, all components of US carrier iPhones from the 4s onward are identical. Simply swap the logic boards.
If you found his to be helpful, please up-vote or Accept Answer.
Punteggio 1
The parts are mostly identical, with possible (not confirmed) antenna differences. Just swap the logic board and the display. The possible antenna differences should not prevent the phone from working entirely
When using the Ifixit guide for repairs, remember DO NOT REMOVE THE BATTERY UNLESS YOU ABSOLUTELY HAVE TO. WHEN REMOVING THE BATTERY, DO NOT PRY IT USING ANY KIND OF SHARP TOOLS. All you need is to replace the display and the logic board, which can be done without removing the battery.
Punteggio 1
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 449
