Salta al contenuto principale
Repair guides and support for cars produced by the British automotive manufacturing company, founded in 1903.
change indicator relay on Vauxhall Combo
My right hand indicators don't work properly and I have been told that it is probably the relay. And wouldn't you know it, apparently it's a real pain to replace? Because of its location. Apparently it is behind the battery and something else. Any help please.
Questa è una buona domanda?
Punteggio 2
6 Commenti
What year is your Vauxhall?
da
It's a 2005 55 plate
da
Does that relay also control the reversing light?
da
any more my light do not work 1.9 vauxhall combo reg 04
da
I have no flasher and hazards . Fuse and relay is ok on vauxhall vivaro 2004
da
Mostra 1 altro commento
Aggiungi un commento
2 Risposte
Risposta Più Utile
Geoff Heyes, the relay is located under the hood, adjacent to the battery. You should see a black weather sealed box. You will need a long extension and a Torx ( I read a T20) socket to remove the cover. The indicator relay is the large yellow one.
information from here
Punteggio 2
3 Commenti:
That's a great help.
Many thanks.
Geoff
da
You are welcome, best of luck to you.
da
This was really helpful to me many thanks
da
This relay is located near the BCM module. It is located under the plastic that covers wiper linkage and motor. There is another plastic that covers BCM module and relays near it.
Punteggio 0
Aggiungi la tua risposta
Geoff Heyes sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 94
Tutti i Tempi: 32,858
