Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
Pression on the display: white stain?
Hi, I've repaired 2 iPhones 4 and 1 iPhone 4S and I've always the same problem, I can't understand.
The display and all stuffs look perfectly, but with a little bit more pressure than normal, there comes a white stain only for one second... Like touching the TV.
Why????
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The screen is an LCD. If I recall correctly, the images are formed by energizing a Liquid Crystal matrix. I believe that when you press on the display, you are displacing the crystals in a manner that allows more of the backlight to show through. Incidentally, I think this also indicates that your replacement screens are not manufactured to the same specs as the one that Apple uses. The glass in an OEM Apple screen assembly is frequently stronger than what is found in many of the less expensive replacement units.
Punteggio 2
Aggiungi la tua risposta
crikketto sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 70
