Salta al contenuto principale
My mom wash my iPod then dry ina dryer by accident
hi my i pod don't work anymore my mom wash because i left my i pod on my shorts then she dry in a dryer after she takes the cloth out of a dryer she fund my i pod and the i pod don't turn on an apple don't cover the i pod with the warranty on water damage you know what can i change o how to repair? thanks
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
The only way is to disassemble the iPod.
then you need rubbing alcohol and a soft paintbrush, then clean the logicboard and the dock connector - but be careful - the parts are tiny. if everything is clean, let it dry and reassemble it.
try charge it with the wall charger - maybe you'r lucky and it will work again
Punteggio 2
1 Commento:
Make sure you leave it powered off for a few days before you plug it in, though.
da
Good! Now you can get a life! :-)
Punteggio -1
1 Commento:
That's not a helpful answer... If someone else were to come along and look at this question, they would not find much of a solution in your answer.
da
Aggiungi la tua risposta
luciano sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,370
