its locked out and said wait 23000000 mins and try again
my I pod went died and its locked out and said try again in 23000000 minates what do I do that's 43 years
Questa è una buona domanda?
joery, the very first thing you want to try is what apple suggest. Follow the instructions on here. If that does not work, try this. YOU WILL ERASE ALL YOUR DATA. Hope you got it backed up. Go into DFU Mode and restore. DFU Mode Connect your iPod to your computer Turn your iPod Off Press and hold the power button for 3 Seconds While continuing to hold the Power button, press the home button as well for 10 seconds Keep holding down the home button, release the power button for another 10 seconds iTunes should now detect the iPod in recovery mode, press OK, and restore your iPod. Now you can release the buttons. If you have not reached this point, then you have not entered DFU Mode. Hope this helps, good luck.
This happened to me as well. What I did was hooked my iPod up to my computer which automatically made iTunes open up. Then somehow the iPod unlocked. I think it did this because iTunes recgonized my iPod, maybe you should try this if you already have your iPod information stored on your computer iTunes.
You have to put it in recovery mode and plug into itunes and restore
How do I do that
Log into iTunes, plug the device into the computer usb jack using a phone power cord. Go to your iTunes, then when you plug in the device a window should pop up. And you can reset it.
The best solutions are to either to to a pawn shop or some place and get it checked out or to wait 45 years.
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 10
Tutti i Tempi: 31,068
13 Commenti
The same thing happened to me and I don't know how to do all this techy computer stuff I don't have a MacBook or a computer with iTunes.
da Ali
Try bringing it to apple they can fix it
da Trenton Borr
what about 313257600 min
da Liu Wilson
Wat about 24122456 mins
da Corey hoban
Welcome to my house..
da Ldlyd
Mostra altri 8 commenti
