Salta al contenuto principale
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Domande Visualizza tutte
Display Backlight bleeding on 2/3 of lcd screen. what to replace?
I bought a used 2009 13" a1181 2.13 ghz MC240ll/a macbook on ebay. Everything works except lcd appears faded out on left upper corner and right lower corner. The fading is irregularly shaped and worse on the left and takes up about 2/3's of screen. It's not that bad and the computer is useable. But it is annoying. It does not change with length of time computer used or moving screen. It did not fix with PRAM reset or with reseating display cable on logic board. Video looks fine when hooked up to external monitor. Would I need to replace whole display to fix or can I just replace video cable? Or could it be inverter board? Any more trouble shooting I should do?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I can think of no reason a controller or cable would cause this problem. I believe the LED display has some bad/damaged traces at the edge(s). Have you run AHT?
If this answer is acceptable please remember to return and mark it.
Punteggio 1
1 Commento:
I don't have install dvd; so am not able to run AHT. Sounds like I would need to replace LED display to fix then.
da
Aggiungi la tua risposta
barelymd sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 462
