I forgot my Galaxy Mini password, how do I reset it
As I switch my phone on, It requires a (pattern) password and I have forgotten it
Questa è una buona domanda?
Hi,
If you make some wrong entries the phone will offer you to log on with your google account. But you must have WiFi connection. You can't make new connection and your WiFi must be turned on from before.
The second way is with adb commands. But for this you must have enabled USB Debugging from before. Otherwise you can't connect it with the PC.
The third way is Factory Reset but you will LOST all your data. Push and hold together vol(+) and power on keys.
With vol(-) chose Factory Reset. The power on key is for ok.
Rimozione password blocco schermo Samsung Galaxy S5
Regards.
omg it worked thank you and keep up the good work
1-code formati https://www.facebook.com/rebels.tn.3
2-conneceter sur wifi entre email et mot passe
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 16
Tutti i Tempi: 15,375
3 Commenti
Did you set a pin number incase you forgot your pattern?
da Cammy
No I never set a pin number
da ant7210558
wifi and bluetooth not working
da wwwharisfarooq
