Salta al contenuto principale
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Domande Visualizza tutte
Domanda Chiusa
I need replacement upgrade HD
Want to up grade from 500gb to 750 gigs. should I get solid state? which one should I look into? I have early 2009 mbp and I still like it and want to fix and improve it. I hear that 1TB does not fit well in this machine so I'd be okay with 750. Thanks.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
A SSD will set you back a bit if you want large storage. I wouldn't recommend that kind of investment for this older system.
A better solution would be a hybrid (SSHD) HD. These SSHD drives are a standard spinning disk drive with a SSD acting as a cache. Seagate makes a 1.0TB drive that will fit your system and also run at the slower SATA II (3.0 Gb/s) I/O speed you'll need here.
Your system can support any 2.5" 9.5mm high drive that is SATA II or can be set for SATA II. I do recommend updating the EFI firmware. Follow this Apple TN on how to check it EFI & SMC firmware updates for Intel-based Macs.
Punteggio 3
Any 2.5" Serial-ATA III (6Gb/s) X 9.5mm drive should work. Be wary of off brands… the tightwad often ends up spending the most money.
Along with size comes energy draw…
If this answer is acceptable please remember to return and mark it.
Punteggio 2
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 221
