Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
20 Domande Visualizza tutte
rear camera is black
Happy new year.
I have changed the charging port and home button to an iphone 4s and rear camera after testing is not working!!!!
It is completely black although it shows the choises on the bottom (video camera etc) and you could swap to the front camera which is working. The shutter on the rear camera is not anywhere and that makes me worry. I have done restore and hard reset but still nothing. Do you thing if I will change the camera it will work? Thanks
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Take a look around the camera connector and make sure you didn't damage any of the filters, resistors or capacitors if you find any missing try to jump them.
Punteggio 0
Make sure there isnt an issue with the little gold grounding finger, and that the plug is seated correctly.
Punteggio 0
Aggiungi la tua risposta
giannins sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 161
