Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2396 Domande Visualizza tutte
water damage and after problem
Hello, my iphone was recently water damaged. I ordered new iphone screen and body except the main board.
I replaced the whole things. but here is a strange problem occur
1. when I connect the iphone to the charger. It goes to the main page but when i disconnect it iphone turned off.
2. Iphone want me to connect to the Itunes before it goes the further process. so when I connect it to my computer. it failed to connect to my computer and turn off before it goes to the main page.(turn off and on constantly)
Questa è una buona domanda?
Punteggio -1
1 Commento
If you have cleaned the board properly and changed the battery, replace the dock connector next.
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
If phone works on charger but not off charger check to make sure battery connectior at logic board isn't loose/damaged. The socket is easy to accidentally liftoff the pads and show the behavior you're describing.
Jessa
Punteggio 1
You need to take it to a repair shop or clean the board yourself. The battery also always need to be replaced when it is water damaged.
Punteggio 0
1 Commento:
I bought the new battery, and I clean the board with revive iphone.
the problem is that computer does not recognize the iphone itself
da
Aggiungi la tua risposta
jake sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 61
