Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
iPhone 5 wifi greyed out even after wifi antenna replaced
So I bought an iphone 5 in eBay to fix it. The screen was totaled so I repaired that first... This is when I noticed the phone would not connect to wifi. I have done all the tricks and noticed the phone will connect to wifi for a short period after paced in the freezer. This drew me to the conclusion the wifi antenna had to be replaced.. After all of that work.. Wifi worked for not even a minute just to fall back to the original problem. Did the same ole trouble shooting and reset and restored the phone a hundred times.... and did the whole heat lamp trick and nothing... I'm at a dead end here... Any one have any ideas???
Questa è una buona domanda?
Punteggio 1
5 Commenti
Where do I get it exactly? I was trying to find the parts for it and I'm kind of new to this. Thank you for the reply :-)
da
Ebay of course. But this is a difficult repair. BGA soldering required
da
To replace the wifi module do you pry the old chip off and clip the new one into place? Or is there more to it?
da
!@#$ ok... Well see how this goes lol.. Thank you
da
First you have to simply rehot the wifi module by hotgun with 180 and check most of the cases such fault was resolved by doing this.If the problem is still same even after doing this you have to replace the wifi chip.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Keisha--
Your phone still has value even with the wifi problem--sell it.
To replace a ball grid array chip, you would probably need to have several years of experience micro soldering, and quality specialized professional equipment. You certainly wouldn't want to try your first bga repair on a phone that has the resale value of your iPhone 5.
Punteggio 2
1 Commento:
I ended up selling the phone for more then I put into it.. Thank you :-)
da
Greyed out wifi is not caused by the antenna, but a defective wifi chip. It does not work properly and sometimes fails to boot up or get recognised by the system. You should replace the wifi module
Punteggio 1
Aggiungi la tua risposta
keisha serrano sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 4,924
