Salta al contenuto principale
Lanciato il 24 ottobre 2011 / processori quad-core Intel Core i7 da 2,2, 2,4 o 2,5 GHz
405 Domande Visualizza tutte
Would you explain and identify a component on the logic board?
Hello,
I tried to replace my girlfriends macbook keyboard after a meeting with lemonade and knocked off a small component...
I dont know how to identify it and if she can use it without it.
Here on this island there arent company's who can fix this really and mostly break more than fixing it. Could it be fixed with some glue or something?
The serial number is: C17GKVH2DV7L
Model nr: A1286
Thanks for your help!
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Piet, that is reference designator C6880 which is a 10UF 20% 6.3V X5R 603 capacitor and is listed as critical on the schematic. This means there is no way you can do without. It is part of the "AUDIO: JACK TRANSLATORS" circuitry. It is an inexpensive, widely available part ( from here for example) I suggest to spend the few $ and replace the capacitor. Hope this helps, good luck.
Punteggio 2
2 Commenti:
Thank you for your help!
da
You are welcome. Thank you for accepting my answer.
da
Aggiungi la tua risposta
Piet sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 160
