Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
iTunes error code 2
Hi guys.
I hope someone can help me I have an iPhone 4 I recently purchased as spares or repair.
It is stuck in DFU mode but when I try to restore it I get this
the iphone iphone could not be restored. an unknown error occurred (2).
I have tried all sorts to get round it it's supposed to be an issue with antivirus but I don't have any antivirus as I only use Mac.
I've tried on both my iMac & my MacBook Air neither of which have antivirus or any firewall set up.
Interestingly on the iMac I get a different error code I get error 21.
Problem with the iMac is I use it as a server in my workshop so it has a lot of drives & devices plugged into the FireWire & USB ports to unhook it all would be a pain.
But the MacBook Air has nothing plugged into USB except of course for the iPhone.
Other things I have tried iReb I have also removed the logic board from the iPhone & hooked a battery with a dock port to it & tried the restore that way no joy same error code.
Anyone maned a workaround or found a way past this?
Thanks guys
Questa è una buona domanda?
Punteggio 7
Aggiungi un commento
3 Risposte
Risposta Più Utile
i have the same problem, error code 2. trying to restore 7.0.4 but about 70% later it gives me error code 2.
Punteggio 2
Watch that tutorial fixed my iphone 4 https://www.youtube.com/watch?v=0Fl5cf9R...
Punteggio 0
iphone could not be restored an unknown error occurred (2)
help
Punteggio 0
Aggiungi la tua risposta
Kenny Leonard sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 12,997
