Salta al contenuto principale
Repair information for Motorola's Moto X line of mid- to high-end smartphones.
Replace display assembly or just glass?
Hello,
I recently dropped my moto x and shattered the glass. The touch digitizer and lcd seem to work still, so I think the damage is mostly cosmetic.
The guide on this site only shows how to replace the display assembly, I've found the glass itself for sale much cheaper.
My question: is it possible to replace just the glass, or do I need to swap the entire display assembly? If I can replace just the glass, does anyone have a guide to doing that?
Thanks!
Questa è una buona domanda?
Punteggio 5
1 Commento
where did you get the glass from??
da
Aggiungi un commento
5 Risposte
Risposta Più Utile
Kolton, just like most other phones, the assembly is glued together using OCA/LOCA. As such it is almost impossible for a DIY'er to replace just a single part of the assembly. For a successful repair, I suggest that you replace the complete assembly. Yes, it will be more expensive but it will ensure that you have a working display. Hope this helps, good luck.
Punteggio 3
I definitely second this
Punteggio 0
Third that Norton and here are fine other thoughts.
. it looks like a machine to reliably separate glass and digitizer is at least $300 and then the machine to ensure that you can I have a new digitizer attached to an existing LCD without any bubbles or distortions is about 1500 dollars. I mean there are people who use heat guns and infrared thermometers that seem to be able to make the replacement on certain models but generally the repair is just getting harder. I noticed that with the LG g3 any crack in the digitizer/glass tends to disable the entire touch screen whereas previous phones can totally operate without a problem with a single crack. It almost seems intentionsl. There it's no way that went unnoticed. A crack had me shelling out 150$ instead of the usual 15$ for a premium screen protector with strong adhesive. I actually noticed there is a "your screen is damaged" mode. there is a way to make calls with puree and volume buttons and this LG software helps you. Thanks, but I'd prefer a phone that didn't self destruct with one crack.
does anyone know if replacing cracked screens is something that self phone manufacturers have figured out how to monetize? I loved that a &&^&@@ digitizer on the HTC evo meant 20$. I now use tempered glass screen covers although I'm not yet sure they're the same as having a gorilla glass and digitizer layer that us unglued yup the lcd.
Punteggio 0
1 Commento:
Sorry for typos I'm using voice recognition and swipe and I refuse to proofread on purpose :-)
da
More and more people start using OCA Repairing
Punteggio 0
I’m afraid not. The entire display panel is one unit. The actual display glass is a very delicate glass and it is stuck to the external, tougher glass using a special adhesive. If you try to separate the two, it will almost definitely crack the delicate display glass. So if you do damage the screen glass and your display is still working, you need to either replace the entire display panel or you need to just stick up your broken display with screen protectors and cellopane tape.
Punteggio 0
1 Commento:
So what would I need to do if my main screen is cracked and my display no longer works, but I can still adjust the ringer and volume on my phone (my screen is black and won't display anything but still works)
da
Aggiungi la tua risposta
Kolton sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 26
Tutti i Tempi: 9,398
