Are keyboards from 15-inch PowerBooks interchangeable?
More Specifically, can the keyboard and topcase from model A1046 (1.25 GHz) replace that for a model A1138 (1.67 GHz)?
Questa è una buona domanda?
Yes - http://www.ifixit.com/Store/Mac/PowerBoo...=on]|depending] on if they are backlit or non-backlit.
If this answer is acceptable please remember to return and mark it.
Link has not been working since Dec 25. Any other alternative links to the info?
IFIXIT's collection of PowerBook parts is getting thin. At this point your best bet is to goggle the part or check eBay.
Hmmmm, I've looked more closely at ifixit guides for upper case removal and the earlier keyboards don't seem to be the same as the later ones. For example, I've removed the top case in my 1.25 GHz model A1046 and, as the pictures in the guide show, the keyboard has TWO ribbon cables - a narrow amber and a thicker one-inch wide clear cable. Looking at the guides for the 1.5 and 1.67 GHz models A1106 and A1138, I see only a narrow amber ribbon cable. I don't see the inch-wide clear ribbon.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 139
