Salta al contenuto principale
Modello metà 2010, A1278 / processore Core Duo 2,4 o 2,66 GHz
794 Domande Visualizza tutte
after disassembled and reassembled MacBook Pro it works slow
i wanted to clean my macbook pro, so i tried to disassembled every part of it, clean it the put them back together, but when everything is done, my macbook starts to works weird. the cpu becomes "used 99%" which means it becomes very slow. also moving the mouse is like impossible, but just when i plugged in the charger, everything works normal again, cpu is like 15% running. any help pls?
Questa è una buona domanda?
Punteggio 0
1 Commento
How much free space do you have on the hard drive? Do a force quit to see if things are running in the background. (option, command + escape)
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Its possible that there is a loose connection somewhere within the machine, as an intermittent connection between a device with an integrated thermal sensor (such as the trackpad), will cause the sensor to misread, slowing the machine down considerably... but you'd have to open it and check all the connections.
Other than that, it could be a grounding issue, but that would imply that there are important screws missing, as certain logic board screws are used to ground the logic to the aluminium housing. Were there any screws left over afterwards?
Reset the PRAM and the SMC and see if that helps to start with, then reseat the internal connections and inspect cables to make sure none are damaged or split.
i hope this helps
Punteggio 1
Aggiungi la tua risposta
weijie wu sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 176
