Salta al contenuto principale
Lanciato a giugno 2012 / processore Core i7 con Turbo Boost / Fino a 1 GB di RAM Video DDR5
597 Domande Visualizza tutte
Can I replace the glass without replacing entire assembly
I have smashed the glass on my mid 2012 15" MBP. I have found the glass available online, however I seem to remember hearing that the entire display assembly needs to be replaced. (Maybe it was for the retina version?)
Can anyone clarify that I just need to replace the glass and not the whole assembly.
Thanks
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I've done it and won't do it again. What a mess. The old glass comes off in shards and the rubber melts and gets all over. You might search on line for a pro that will do it at a reasonable price.
Punteggio 3
1 Commento:
I would opt to buy the display with the glass, LCD and cover all as one piece.
da
Yes - see step 16 note it's an advanced DIY repair, perhaps better left to someone with experience… but the glass would come off the old one and go back on the same way as earlier models.
If this answer is acceptable please remember to return and mark it.
Immagine MacBook Pro 13" Unibody Mid 2010 Front Display Glass
Guida
MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement
Difficoltà:
Molto difficile
4 hours
Immagine MacBook Pro 15" Unibody Mid 2012
Guida
MacBook Pro 15" Unibody Mid 2012 Teardown
Difficoltà:
Moderato
Punteggio 1
Aggiungi la tua risposta
Alex sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 95
