Salta al contenuto principale
Modello A1286. Lanciato nel febbraio 2011 / processori quad-core Intel Core i7 da 2,0, 2,2 o 2,3 GHz
586 Domande Visualizza tutte
Headphone jack / digital output disabling internal speakers
I have 2 macbook pro's, one late 2008 and a early 2011. Right now both are showing the same problem.
Internal speakers being disabled by the digital audio detection on the headphone jack being turned on by a faulty device.
My question is, after a lot of research, in which problem say to put foreign objects into the headphone jack to try to reset the sensor, is there a way to replace (yes I know its solder in)? Where can I buy the headphone jack only without buying the whole logic board? (which is where its solder in).
Questa è una buona domanda?
Punteggio -1
1 Commento
I am not an expert but I am savvy as in electronics. But I can't find anywhere on the net where to buy a replacement if any. And yes it crossed my mind to simply buy a usb audio port for it.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Soldering logic board components is generally not a DIY project. MLB are easy to destroy. If you are a small electronics/computer repair technician with the special tools, solder and experience to accomplish this task you most likely would not be here seeking advice.
A work around would be to use a USB audio adapter which would contain a headphone jack (USB AUDIO works separate from analog and optical), or, a USB voice quality headset with builit in microphone.
If this answer is acceptable please remember to return and mark it.
Punteggio 1
Aggiungi la tua risposta
Hector Rosa sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 735
