Salta al contenuto principale
La linea di computer portatili MacBook Pro di Apple per utenti avanzati e professionisti. La linea MacBook Pro include varianti da 13, 14, 15, 16 e 17 pollici, e le revisioni principali sono definite da Pre-unibody (originale), unibosy, display Retina, Touch Bar e SoC (system-on-a-chip).
20007 Domande Visualizza tutte
Domanda Chiusa
Why does mds process heat up CPU after hard disk install?
I recently installed a new hard disk on a MacBook Pro Core Duo 2.0 GHz and migrated accounts from the older disk. The Activity Monitor has started showing the mds process ramping up suddenly and dominating the CPU usage at over 100% -- occasionally as high as 170%. Then the process dies down until something else causes it to ramp up again.
After two days without problems, this cycle has begun to repeat itself. Can someone explain why this would happen, and why so sporadically? Thanks in advance.
Questa è una buona domanda?
Punteggio 0
1 Commento:
What hard drive did you install? What speed?
da
Aggiungi un commento
1 Risposta
Hitachi 320GB 5400rpm. About 100GB is being used. The MacBook is running MacOS 10.6.3. FWIW, I stepped away from the machine for a couple of hours and came back to find the mds process running intensely.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 758
