Salta al contenuto principale
1.4GHz or 1.6GHz Processor / 64GB or 128GB SSD
162 Domande Visualizza tutte
Placement order of diffuser sheets?
I'm replacing the screen on a friend's MBA (A1370). Upon removing the broken LCD from the bezel, The 3 sheets of plastic behind it fell out and spread on the floor. Is there a particular order these must be put back in? I'm guessing they must have an order of some sort. Otherwise it will be hit and miss, Trial and error.
Thanks in advance.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
its a very difficult one to describe in words, but the white backing sheet is obviously first, then the thickest plastic sheet lines up with the LED strip at the bottom... then the last few need to be put in order as well. The one with a darker shade, and an almost matte finish is the last one, so the more metallic reflective one goes in-between the thicker one and the last one...
i hope this helps.
Punteggio 1
2 Commenti:
I've got the same issue. I can't quite understand what order they go in. Can somebody help me with front to back placement - front being closest to the screen? Thanks.
da
Indeed this seems there are only 4 components but my kit came with 5 sheets. Can you please help us figure this out?
da
Aggiungi la tua risposta
Djdat sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 15
Tutti i Tempi: 2,991
