Salta al contenuto principale
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
Can I replace the inverter with one from a different model?
I have a Macbook Core Duo that needs to have it's inverter replaced. I have MacBooks around that are older models..but their inverters are in good shape. Can I use those inverters instead of buying new ones?
Questa è una buona domanda?
Punteggio -1
1 Commento
What are the last three digits of your computer? That will allow us to properly identify it and if possible cross match the parts.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Brittney, the part number for the MacBook listed as the Device is 922-7375. This inverter is compatible with :"
MacBook 13.3" 1.83GHz Core 2 Duo (A1181) - Late 2006
MacBook 13.3" 1.83GHz Core Duo (A1181) - Mid 2006
MacBook 13.3" 2.0GHz Core 2 Duo (A1181) - Early 2009
MacBook 13.3" 2.0GHz Core 2 Duo (A1181) - Late 2006
MacBook 13.3" 2.0GHz Core 2 Duo (A1181) - Late 2007
MacBook 13.3" 2.0GHz Core 2 Duo (A1181) - Mid 2007
MacBook 13.3" 2.0GHz Core Duo (A1181) - Mid 2006
MacBook 13.3" 2.13GHz Core 2 Duo (A1181) - Early 2009
MacBook 13.3" 2.16GHz Core 2 Duo (A1181) - Mid 2007
MacBook 13.3" 2.1GHz Core 2 Duo (A1181) - Early 2008
MacBook 13.3" 2.2GHz Core 2 Duo (A1181) - Late 2007
MacBook 13.3" 2.4GHz Core 2 Duo (A1181) - Early 2008
MacBook 13.3" 2.4GHz Core 2 Duo (A1278) - Late 2008 "
from here. So, any of those computers will have an inverter compatible with the one you need. Hope this helps, good luck.
Punteggio 1
1 Commento:
Thank you! All I needed to know.
da
Aggiungi la tua risposta
Brittney sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 110
