Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Domanda Chiusa
Power / lock button intermittently unresponsive
I have two friends with very similar issues. Both have iPhone 5s (5, not 5s) and both are complaining that their power buttons frequently don't respond to clicks. They've taken the iPhones out of their cases, tried restoring, power cycled the device, etc with no change in behavior.
I've taken a look at each and tactile feedback is still present, you can feel the click when you press the power button, but 25-50% of the time the button press doesn't register with the device.
Has anyone else experienced this? If I were to repair it for them would the likely part be the Audio Control & Power Button cable?
Immagine iPhone 5 Audio Control and Power Button Cable
Prodotto
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
That is the cable to start with if you want to go straight to the part.
Punteggio 1
any update on this post? Did you replace the part?
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 578
