Salta al contenuto principale
Modello inizio 2011, A1278 / processore i5 2,3 GHz o i7 2,7 GHz
782 Domande Visualizza tutte
Domanda Chiusa
Display flicker on certain grey/blue gradients
I have this flickering issue on my display on grey/blue gradients like for example in the Spotify interface. Only the gradient locally has some flickering.
here is an example: http://imageshack.us/photo/my-images/132....
I did have a fall with my laptop a year ago, but had no issues whatsoever at the time.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I'm not seeing any image - connect to an external monitor. If you see the same thing it's your VGU/VGC and therefor a logic board problem. If you do not the problem is related to your internal display chain or (most likely) the LED. It should still be under waranty - I would file a claim or contact Apple support.
If this answer is acceptable please remember to return and mark it.
Punteggio 1
3 Commenti:
It's not that I'm not seeing any image, it's just the gradients that have a slight flicker locally, not the whole screen.
I tried connecting it to an external monitor, and the problem is not reproduced on there.
How would it still be under warranty? It is over 2 years old?
da
I meant your example link didn't work for me - I saw nothing. I was thinking of Apple Care - though sometimes there are extended warranties.
da
You mean you didn't see the flicker, because it's just on imageshack.
Oh yeah we have a standard of 2 years warranty in the EU so I didn't really care about Apple Care, but I'll go check in the store anyways.
da
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,388
