Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
What would cause Error 29 in iTunes on iPhone 4
I had a shop recently replace my screen on my iPhone 4. After a few days my phone would keep rebooting after 2 minutes every single time. I closed all the apps and turned everything off, including cellular, 3G, roaming and it still keeps rebooting... So i decided to do a restore via iTunes. Now Every time i do a restore and update I keep getting Error 29 in iTunes. I read that error 29 usually means a bad or incompatible battery. I tried batteries from two different iPhone 4. Both were original batteries. I also tried different computers, different cables and I during the update process it gets 3/4ths done and I'm getting error 29 on iTunes. The phone is back on recovery mode..... I can't get it out of recovery mode and I can't get it to update.....
Could the screen replacement cause this error 29. ? Is there any other way to get out of recovery mode or update my iPhone ?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
change ur battery & then do update process 10000% tested
Punteggio 0
I've been having the exact same problem. I got my screen replaced and since then the battery is having the exact same issues that you described above. How do you change the battery?
Punteggio 0
1 Commento:
Sostituzione Batteria iPhone 4 Verizon
This is for the verizon if it's not the verizon or sprint go to the guide for regular iphone 4
da
Aggiungi la tua risposta
Mike sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 4,843
