Salta al contenuto principale
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Domande Visualizza tutte
Domanda Chiusa
iPod 4th gen. white screen after screen replacement?
Ok, so my one of my friends was drunk and saw my iPod 4th gen. charging on the wall and picked it up and chucked it. The screen shattered, but the touch still worked and stuff. I looked up the price of sending it to apple for repairs and I thought it was ridiculous. So I ordered a new screen to just replace it myself. I got the screen but as I was trying to connect one of the cords, it snapped. So I ordered a new one and was extra careful that time. So I got the screen all attached and I turned it on before putting it all back together to test it. The lock screen came up, but the touch wasn't working. I double checked the wires that have to plug in but it still didn't work. So I thought maybe it was the protector on the back of the screen (the LCD screen I think) and I pulled it off. As soon as I did that, the screen faded to the white screen of death. I quickly put the protector back on. It was still on the white screen of death so I just put the cover back on the battery and motherboard and closed it without glue. I tried a soft reset but when I do that it just shuts it off. And when I try a hard reset, (still on the white screen) It seems to activate the IPod voice control. The voice control will say "no match found" or it'll start playing my music, and other various voice command options. It's all very weird. I even tried plugging it into Itunes. I would try a restore, but I really don't want to loose any data, and when I try backing it up it says I have to enter my passcode on my IPod which is clearly not an option. I really don't wan to loose my data, but I need help. Could it have been a faulty screen? I ordered it off amazon.
Questa è una buona domanda?
Punteggio 0
1 Commento
update: I (very unwillingly) did a restore but still the white screen! thanks for advice though, any more would be greatly appreciated.
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
You probably need to restore it. I've had this happen to me a couple of times but I didn't have the luxury of being able to restore the phone with the new screen on. The thing that worked for me was to put the old screen back on and restore it. I couldn't even get itunes to pick up the ipod with a new screen, that's why I put the old screen on. For some reason the old screens worked so I then restored them and after restoring I tried the new screens and they worked. Unfortunately, I really don't think there's anyway to get around restoring the device.
Punteggio 1
I had the same problem with a new LCD/Digitizer replacement for a Iphone 4. The old display cable was broken so I couldn't use the old display to restore it. Also, iTunes wouldn't even see the phone if I had the new LCD/Digitizer plugged in. So, I unplugged the new digitizer and LCD cable, attached my USB sync cable and pressed and held the HOME and POWER button until iTunes saw it in recovery mode (about 60-90 seconds). Then I had iTunes restore the phone which took about 20 minutes. I then had a problem with the proximity sensor not working because I had a color after market screen. The problem is too much light coming in which can be fixed with proximity vinyl repair kit: http://www.baremodsiphoneparts.com/proxi...
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,132
