I have been having the common experience of a Dell Inspiron 1501 laptop refusing to recognise its genuine Dell external power pack, which was supplied with the laptop. It will run with it but I get the message that the system will be slower and the battery will not charge.
Though this happenes most of the time there were occasions when the laptop started and ran normally, thus giving the discharged battery an opportunity to fill up again. I wondered what was different on these occasions and tried to spot what it might be.
It took a long time but eventually I recognised a pattern and began to treat the equipment in a specific way. The result was a success, because since I began to adopt an amazingly simple procedure the laptop has accepted the power pack every time. This has been going on for some weeks now, so I feel confident to share it. Here’s how.
I begin with both the laptop and the power pack turned off. Then I turn on the power pack and wait about 10 seconds. Then I plug it into the un-powered laptop. At this point I wait and watch until the little green light that indicates charging flickers after a few seconds, which usually does, though not if the battery is already at 100%. Finally I press the start button and it boots and operates as it should.
I have no idea why this should work, but on my laptop it appears to be reliable. The advice to plug the power pack in and then turn it on fails every time. It is clearly the wrong sequence on my laptop.
Votato
Annulla
Punteggio
0
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
8 Commenti
Have you checked the AC adapter to see if it is working?
da oldturkey03
I have checked the AC Adapter and tried an alternate one as well. That did not resolve it.
da Jarrett Lott
I had the same problem. I never believed it would be so easy to fix I actually brought my computer to the office hoping that a technician would be able to assit me. But I just removed the RAM and reseated it and almost magically the laptop powered up.
da Ian Furlonge
Hi,
I spilled water on my laptop. I shut it down, opened it up and dried but it did not start. I left it be for a year, than I needed something from the dard drive so I tried to start it, just for fun, (I was going to take the hard out and use as external), but it started again.... But the battery was very low and it turned off, I took the charger, plugged it in but nothing happend.... No led turns On, no power gets to it, nothing... Could it be the same thing? Or what could it be? It worked when the battery had power... Could something be burned and doesn t let the power go to the battery? Or to the computer? :( or is it this bug? Thank you
da Mihaela Giorgiana Dogaru
I just had this issue with my Dell 3158. After finally resolving touchpad issues by replacing the motherboard and touchpad, it began having power on issues. Today it turned into a paperweight so i returned it to the store and got a HP instead,
da Stephen Tan
Mostra altri 3 commenti
