Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2193 Domande Visualizza tutte
Domanda Chiusa
How to permanently disable wifi
Want to disable WiFi but still be able to make calls and send text. If I remove the WiFi antenna and do not replace it, when reassembled (without WiFi antennae)will I be able to still make/receive calls and text messages? Do not want to just temporarily disable WiFi. I need to remove and permanently disable it. Thank you for any assistance you can provide
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
That should permanently disable wifi without interfering with any other functions of the phone except for bluetooth because the wifi and bluetooth antenna are one part. If it does happen to interfere with something else, you can always reinstall the wifi antenna.
Punteggio 1
7 Commenti:
Thank you! Your help is appreciated
da
I tried this and I still have wifi without an antenna! How is that possible? What else can I do to disable wifi?
da
I am trying to disable wifi on an iPhone 4.
da
Just because you disconnected the antenna doesn't kill WiFi services (or any other service you pull the antenna) it only limits the range of the signal.
da
I don't know of any way to permanently disabling WiFi here other than disabling within iOS its self. Maybe if you explain why you need to do this we could try seeing what options you have.
da
Mostra altri 2 commenti
Put a restrictions code on it believe me he won't find a way around it if is entered wrong to many times it locks him out of phone
Update
Or look for a iPhone 4s with greyed out wifi forsale these are going really cheap
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 5,993
