Salta al contenuto principale
Repair guides and support for full size headphones that encompass the entire ear, also known as circumaural headphones.
108 Domande Visualizza tutte
USB cable cut after splitter
My USB piece of cable on my turtle beach earforce xl1 headphones got cut when I stripped some of the black covering there is only insulation and red wire with what looks like some copper in it, is this simply sader together use some shrink wire and it should work? Or is it more complicated because of this funny looking red wire if u would like a picture of what it looks like I can send u a photo via email.
Questa è una buona domanda?
Punteggio 0
1 Commento:
Brock McCullough, it will help if you post some images of your wire situation. Use this guide Adding images to an existing answer to add images to your question.
da
Aggiungi un commento
3 Risposte
Wires are wires are wires.... if you nicked the insulation, cover it to stop a short. If you severed the wire, splice it and cover it. Liquid electrical tape or shrink tube is perfect.
Punteggio 0
many of the turtle beach sets, use 2 inputs, one from the rear for game sounds, and front for mic/voice, then you can adjust them with the mixer box on the set you can use a headset splitter mic/audio adapter to seperate the mic from speakers on it
Punteggio 0
Cable Splitter is really helpful to those persons who actually wants to save their money.
Splitter helps in a combination of Tv and Bandwidth.
Cable Splitter Splits the frequency in between USB Cable.
Punteggio 0
Aggiungi la tua risposta
Brock McCullough sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 195
