Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Does anybody know what this cable is/does?
Last night, out of nowhere, my iPhone 5 started acting up and getting real glitchy. I locked/unlocked it and the LCD had a grid pattern behind my normal wallpaper and the digitizer isn't responsive.
Thought it was just a bad session, so I hard reset it...still no response and flawed picture.
Thought it may be a problem with iOS 7.0.3, so I restored and went back down to 7.0.2...still no response and I lost everything (couldn't back my phone up because Find My iPhone was running and I couldn't unlock my phone to turn it off)
Thought the LCD must just be bad, swapped it out and it still had the problem.
Sooooo I tore the whole phone down and found that this cable (See linked picture) was screwed in, but tore in half. It's one of the two that are at the top of the LB next to the camera.
Does anybody know what this cable is? What this cable does? And how could I go about fixing it? Looks to be soldered in, which I'm about to try doing. But I don't even know what to begin searching for in order to find somebody who can. Help help help
Tearing my hair out with this one :/
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
That is the Upper Cellular Antenna connector. Fixing this improves reception and under some networks like DC-HSPA or LTE, provide MIMO reception for download speed.
Image artifacts usually result from faulty LCD flex cable or LCD driver chip or CPU video output. any of these are expensive repairs
Punteggio 1
Aggiungi la tua risposta
Phil sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 180
