How to repair faulty earphone jack
How do i get at the earphone jack to replace or repair it
Questa è una buona domanda?
You would need to replace the entire logic board, or as nick said, you would need to do some intense soldering. If I were you, I would get a USB sound card and this would bypass the sound card built in:
While you can repair this board and just replace the jack, you're going to need to so some SMD or tight through hole soldering.
Follow this to get the board out and repair the jack: MacBook Unibody Model A1278 Logic Board Replacement
its not intense at all if you have ever done any PCB soldering at all. its easier to replace than a capacitor even, you don't have to worry about bending it this way or that and breaking it off.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 9
Tutti i Tempi: 4,184
1 Commento
thanks for the info Gabe Chai/nicksmacan,i guessed it would be messy,kind of vacate the house,warn
the neighbours, pails of water to hand,send the kids to their grandmas. thanks again.
da luke walsh
