Salta al contenuto principale
Modello inizio 2011, A1278 / processore i5 2,3 GHz o i7 2,7 GHz
782 Domande Visualizza tutte
Can I swap the logic board with a 2009 MacBook?
Hello,
The logic board in my early 2011 MacBook Pro is bad. The thought of buying a new logic board kills me, so I've been trying to figure out other options. I have a 2009 macbook with a bad display, but a functioning logic board. The serial numbers are identical. I know it's a long shot, but can the logic boards be swapped?
Thanks in advance!
Cassandra
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You mean the model numbers... I think the graphics card/display LVD connectors could be problems. Look at them visually for connector/port mounting screw differences.
Externally, the "Early 2011" and "Mid-2010" lines unfortunately use the same model numbers as several earlier MacBook Pro models and EMC numbers are not listed at all, so they only can be externally differentiated by the last three or four characters of the serial number courtesy of EveryMac.com's Ultimate Mac Lookup feature (the last three characters for models that have eleven character serial numbers and the last four characters for models that have twelve character serial numbers).
A general rule of thumb is logic boards most often swap between the same, but not different years of manufacture... sometimes the difference between early, middle and late are enough to cause incompatibility
If this Answer is helpful please remember to return and mark it Accepted.
Punteggio 1
Aggiungi la tua risposta
Cassandra sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 117
