Salta al contenuto principale
The Skullcandy Skullcrushers Subwoofer Stereo Headphones in Black Pinstripe will literally pump the music right into your head! These power packing headphones feature an adjustable in-line bass amplifier and speakers with industry first built-in vibrating subwoofers. You can adjust the amount of bass effect with the in-line control wheel.
11 Domande Visualizza tutte
Domanda Chiusa
Bass does not work and not works periodically. battery holder
I had my headphones for a year. All of a sudden, the bass goes on and off. I opened the battery compartment and sometimes when i listen and press the battery towards the minus, the bass comes back on. Is there a way to adjust the metal to have the bass on? And my battery works too.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Patrick Chan,your negative post is a simple spring, and you could just pull it to elongated it. Do make sure that this is the problem, check the ground connection on your board as well as the solder connection to the wire.
Punteggio 1
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 3,244
